Activity Forums Blackmagic Design Capture to DV codec through SDI input?
  • Capture to DV codec through SDI input?
    Posted by David Zimmerly on June 20, 2007 at 8:06 pm
    Hello all,
    This is my first time on this forum. We are wondering if we can capture to the DV codec through the SDI input of the DeckLink HD Pro PCI-X card. We want to use DV as an offline resolution for HDCAM downconverts through SDI. We do NOT want to have to go in to the Mac through FireWire. The documentation is not really clear about this point, so I appeal to this group to help us out.
    David
    David Zimmerly replied 19 years, 2 months ago 3 Members · 3 Replies
  • Ryan_j
    June 21, 2007 at 6:10 am
    As far as i know and i could be wrong is using a DV to SDI converter.
    Cheers Ryan.
  • Steve Regian
    June 22, 2007 at 12:18 am
    Sure… you will use the Black Magic DV easy setup and you can control the deck through RS-422. We do this all the time… even with DV material.
  • David Zimmerly
    June 22, 2007 at 1:12 am
    Thanks, Steve. I was pretty sure you could do this (as we do with all of our Avid systems) but it just wasn’t explicit in the BlackMagic documentation.
    David
