Activity › Forums › Apple Final Cut Pro Legacy › Capture Speed Issues?!
  • Capture Speed Issues?!
    Posted by Ben Youngerman on January 26, 2009 at 9:57 pm
    I am working on a multi-cam edit (2 angles). After capturing the 2 tapes from the shoot, one plays back sped up and loses sync with the aduio when it is edited into the multiclip sequence.
    What went wrong?
    As far as I knew, both angles recorded at 29.97 fps, but I am now suspecting that one was shot at a different speed. It did not require any rendering once captured, it just plays back slightly sped up. Should I recapture with different settings?
    Any advice would be appreciated.
    Ryan Spanger replied 17 years, 8 months ago 2 Members · 1 Reply
  • Ryan Spanger
    January 27, 2009 at 7:25 am
    What format did you shoot in?
    What is the approximate length of each clip?
    Did you log and capture or capture now?
    Did you use firewire to capture?
    Does one clip slowly drift out of sync, becoming increasingly out of sync as time passes, or is it constantly out?
    Ryan Spanger
    Dream Engine – Video Production Melbourne
