Activity Forums Apple Final Cut Pro Legacy Capture Settings, HDV down-converted
  • Capture Settings, HDV down-converted
    Posted by Adrianne on November 14, 2007 at 3:27 am
    Hello,
    Before we start capturing 30+ hours of HDV footage, we wanted to double-check that our settings are correct. If anyone can help, it would be much appreciated.
    1) We are capturing 30 hours of HDV footage, shot with a Sony V1U at 24p, and down-converting it as DV NTSC footage (to be re-captured down the road in HD).
    I am curious if the following capture setting is correct:
    Quick-time Video Settings:
    Compressor DV/DVCPRO-NTSC, Quality 100%
    As a side-note, when would you compress at the ‘easy setup’ option H.264, Quality 75%?
    2) We’d like to combine this eventually with previously-shot SD 30 frames material. We know we can work with both formats in FCP 6 timelines, but does anyone foresee any problems? We’re considering eventually buying a software program to give the 30f footage a 24p look. Does this seem like the best approach, and if yes, do you recommend a particular software for this?
    Thank you in advance,
    A.Anderson
    Adrianne replied 18 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
