Activity Forums Apple Final Cut Pro Legacy capture settings
  • capture settings
    Posted by Iain Mackinnon on November 4, 2008 at 4:23 pm
    Right, I’ve used at least 6 differrent DV cameras now with FCP HD4 and no matter what i do, when i load it in, the quality is rubbish. It looks crystal in the viewfinder but as soon as it’s captured, if i try and blow it up or write to DVD i suffer HUGE loss in quality.
    I’ve never changed the preset settings for capturing or for burning so treat me like a 5 year old ok?
    Please, Please can someone tell me what to do? I’m not asking for much, just a decent quality DVD.
    I used to spend my time wondering, now it’s all used up rendering.
    Rafael Amador replied 17 years, 10 months ago 2 Members · 1 Reply
  • Rafael Amador
    November 4, 2008 at 5:28 pm
    Hi lain,
    The movies you get in your computer are 100% the same you have in our camera. No transcoding, no re-compression.
    If you want to make your DV footage look better:
    -Drop it in a sequence with a 422 codec (DVCPro50, Apple 8/10b Unc, PhotoJPEG 75%,..)
    – Make a bit of Color Correction.
    – Before exporting apply a “Chroma Smoothing/Sharpening” filter. FC used to have a 411/422 Chroma Smooth filter, but is not there any more. Adam Wilt have a free one (only for 411 footage) here: https://www.adamwilt.com/SteppyEdges.html
    If you are in PAL land, you need to get the Nattress “Chroma Smooth/Sharpen”. Works incredible. If you are applying others filters, this one have to be set the first in the stack. Although I apply it in the last moment, otherwise no RT preview.
    Rafael
    http://www.nagavideo.com
