Activity Forums Creative Community Conversations Capture SDI over firewire
  • Capture SDI over firewire
    Posted by Rich Hawksworth on February 24, 2014 at 8:00 pm
    I have a library of DVCPRO 50 tapes and a Panasonic AJ-SD93P deck. I’ve traditionally captured through an IO HD—SDI out of the deck. I’ve discovered that the IO HD is not supported under FCPX. I don’t have to access these tapes very often (like this is the first time in several years) so I’m loath to invest a lot in a “new” capture solution. Any suggestions for an economical ingest setup?
    Rich Hawksworth replied 12 years, 7 months ago 2 Members · 2 Replies
  • Shane Ross
    February 24, 2014 at 8:24 pm
    Does the deck have Firewire connectivity? DVCPRO 50 traditionally does.
    The IO devices are now only “O” with FCX…they only work to output to a monitor. The only way to capture directly into FCX is via firewire.
    You can, however, capture using the IO makers software. AJA does make a capture utility called AJA VTR EXCHANGE. You can capture with that, and you IO…and then import that into FCX.
    Shane
    Little Frog Post
  • Rich Hawksworth
    February 24, 2014 at 8:27 pm
    Unfortunately the FW port on the deck fried a long time ago. $1500 to replace the FW card wasn’t worth it while the IO HD was working. I’ll try the utility you suggested–thanks!
