Activity Forums Apple Final Cut Pro Legacy @#%! capture screen
  • @#%! capture screen
    Posted by Troy on April 27, 2007 at 9:46 pm
    Okay…when we scrub in log and capture, we see our footage just fine, but when we use capture now, the capture screen that comes up is black. Not showing the footage. We’re trying to capture HD1080i using a blackmagic HD card. The footage captures fine, we just cannont see it while we’re capturing. We have 12hrs of footage to capture and don’t have time to log everything we need. I’m sure I’m just missing a setting..The manual was no help and I found nothing searching this board. any suggestions? Thanks
    -Troy Hill-
    Destination Above and Below
    G5 Dual 2.7
    2.5gb DDR
    BlackMagic HD with HDLink
    Andy Mees replied 19 years, 4 months ago 5 Members · 4 Replies
  • Shane Ross
    April 27, 2007 at 10:37 pm
    First time I heard of that issue.
    Can’t hook up a monitor to the deck and view it directly from the tape?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Michael Alberts
    April 28, 2007 at 4:43 am
    Are you not seeing the image in the Capture Window or the HD monitor which is hooked up to your Blackmagic card? You should see the image on your HD monitor.
    Under normal circumstances you should also be seeing the image, albeit not full rez, in the capture window.
    Michael Alberts
    Ambidextrous Productions, Inc.
  • Steve Connor
    April 28, 2007 at 11:19 am
    Do you have “video desktop” enabled on the BMD card preferences. If you do try turning it off to see if it makes a difference.
  • Andy Mees
    April 28, 2007 at 11:23 am
    you may want to check that you have “Mirror on desktop” enabled in your A/V Devices setiings (Final Cut Pro > Audio/Video Settings… >> A/V Devices tab)
