Activity › Forums › Apple Final Cut Pro Legacy › Capture Scratch inside Capture Scratch
  • Walter Biscardi
    February 4, 2009 at 7:28 pm
    If you select the Capture Scratch folder at the beginning of a project, FCP will create a new Capture Scratch folder in there.
    Simply select the Hard drive you want to capture to, FCP will always go to the default Capture Scratch folder.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • John Fishback
    February 4, 2009 at 7:32 pm
    It shouldn’t do that on its own. If you’re not careful when you point FC at the capture location this can happen. I used to create a different folder for each project on my RAID. I stopped doing that because when I had multiple projects going if I forgot to reset FC to the correct scratch folder I’d end up mixing project media.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
