Activity Forums Apple Final Cut Pro Legacy Capture Scratch
  • Capture Scratch
    Posted by Farshad Raoufi on May 5, 2010 at 4:47 pm
    Hello,
    I want to reformat my mac, so I am transferring all my files over to my external hd, but when I come to move the clips from my “Capture Scratch” I get the following message :
    “The operation can’t be completed because an unexpected error occurred (error code 0).”
    Can anyone help me out?
    Farshad Raoufi replied 16 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    May 5, 2010 at 9:27 pm
    Sounds like something wrong with the files in there. Do they play OK? MIght want to try a software program to clone that drive with. Carbon Copy Cloner or SuperDuper… both free just google them.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Farshad Raoufi
    May 5, 2010 at 9:38 pm
    The files work fine, they open, even in my fc timeline they work, i don’t want to re-capture the footage because i’ve synced the audio, its a music concert, I’m trying to put the capture files onto my hard drive, those two softwares you suggested copy the hard drive , i only want the footage!
  • Farshad Raoufi
    May 5, 2010 at 9:41 pm
    could it be that my external hard drive is ms-dos? and not os x?
  • David Roth weiss
    May 5, 2010 at 9:45 pm
    Run Disk Warrior on both drives ASAP.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Farshad Raoufi
    May 5, 2010 at 9:48 pm
    can it be because my external harddrive is ms-dos and not os x? is that why it says it cant be moved? because i can move the .mov files anywhere on the computer itself
  • Brian Prom
    May 5, 2010 at 9:53 pm
    Have you looked at the file permissions? Do a “Get Info” on the containing folder, set them to Read & Write and apply that the the enclosed files. That might work.
    Also make sure you are doing a copy and not a move when you transfer them to the second drive.
  • Farshad Raoufi
    May 5, 2010 at 10:06 pm
    Thanks for your help everyone, it was because my external hd was ms-dos, i changed it to mac os extended journal and it worked!
