Activity Forums Apple Final Cut Pro Legacy Capture quirk
  • Posted by Quaadnyc on May 8, 2006 at 6:03 pm
    I had a drive go down so i wanted to do a batch capture to a new drive (i’m using a second internal drive for the time being, just so i can continue to work while my xraid is out.) If i do batch capture of a single clip, it finds the clip, captures it, then returns to the window that says “ready” instead of “finished”. I hit the “ready” button and it captures my clip again. It did this four times before i decided to just try to hit “cancel”. I did, and the clip had been captured fine, and only once.
    weird. Is this happening to anybody else?
    Dual 2.7 GHz PowerPC G5
    4 GB RAM
    FCP 5.04
    Decklink HD Pro
    Capturing SD from DigiBeta via SDI
    quaad NYC
    G5 Dual 2 GHz
    2Gb RAM
    FCP 4.5/AJA KONA SD
    Quaadnyc replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
