Activity Forums Adobe Premiere Pro capture quicktime format?
  • capture quicktime format?
    Posted by Tony Rain on September 15, 2006 at 3:43 am
    i cant seem to find a setting in Premiere Pro where i can capture to quicktime format. the default captuer is AVI. is it possible to capture to quicktime format?
    thanks!
    Tony Rain replied 20 years ago 4 Members · 6 Replies
  • Mike Velte
    September 15, 2006 at 11:04 am
    No,
    Premiere is a Windows only app and uses Windows DirectShow support for device control and camera drivers.
  • Steven L. gotz
    September 15, 2006 at 8:02 pm
    If you want to capture to Quicktime, I suggest using a Mac. If you want to edit on a PC, Quicktime is more trouble than it is worth. DV AVI for a PC is almost the same as a Quicktime capture, but the header differences are significant and troublesome.
    Steven
    https://www.stevengotz.com
  • Tony Rain
    September 15, 2006 at 9:41 pm
    I usually use quicktimes when working in after effects, thats why i wwould like to be able to capture quicktime. i guess i can give avi a try in after effects?
    thanks for the insight!
  • Steven L. gotz
    September 16, 2006 at 6:03 pm
    After Effects will treat DV AVI the same as it does the same data rate and general format of Quicktime. It should be fine.
    Steven
  • Michaelw
    September 17, 2006 at 6:58 am
    I learned the hard way that Premiere Pro and .mov files don
  • Tony Rain
    September 20, 2006 at 8:11 pm
    i thought premiere, in older versions, captured to quicktime?? i used to use premiere, i believe version 4?? and it captured QT’s.
    anyways, thanks for the responses!
