Activity Forums Adobe Premiere Pro Capture question
  • Capture question
    Posted by Reggie Spires on May 20, 2008 at 7:09 pm
    I have recorded Footage on an XH-A1 Canon in 24p HDV mode. I am not going to produce it however in HD. I did it that way for archive purposes and best quality.
    How should I capture it and where in the capturing process should I convert to standard Definition. I have a AJA Xena LS card and I am capturing Firewire.
    Is there any benefit over capturing with just the PPro presets?
    Thanks in advance for the help.
    Reggie Spires
    Magic City Group
    Magic City Productions
    Magic City Advertising
    David Dobson replied 18 years, 3 months ago 2 Members · 1 Reply
  • David Dobson
    May 20, 2008 at 11:25 pm
    If you capture via firewire, you are stuck with HDV. However, I have done this and what works best is to capture in HDV. Then create a new project in Standard Def (wide screen, though I guess you could do full screen) and then import that captured HDV footage into that project and then cut it into the timeline. You do have to resize the footage, but it’s not as tedious as it sounds PLUS you have the advantage of being able to reframe it (almost as if you shot 2 cameras!) Depending on your settings and system, you should be able to play the HDV footage unrendered in the timeline (set quality to automatic)and render it once at the end. I did this in 1080i60, but the same should apply to 720p24.
    The other option is edit in 720p24 and export a standard def final when you are done. You don’t need a substantially faster system to work in HDV then DV (they have the same data rate.)
