Activity Forums Blackmagic Design Capture question
  • Capture question
    Posted by Mihail Angelov on February 28, 2006 at 10:29 am
    I’m curently using a PPro 2 with decklink exreme, I was wondering is there any possibility to capture in different format in one project (DV PAL and 10bit uncommpresed video PAL).
    Kristian Lam replied 20 years, 6 months ago 2 Members · 1 Reply
  • Kristian Lam
    March 2, 2006 at 5:05 am
    If your DV PAL is via firewire, it’s possible. You need to start with a 10-bit uncompressed project, then switch the capture settings.
    If you’re planning to capture non firewire video into the DV PAL format as well as the 10 bit uncompressed format, then you’ll need to use 2 seperate projects. However, the files can then be combined into a 10 bit uncompressed timeline in Premiere.
    regards
    Kristian Lam
    Blackmagic Design
