Activity Forums Apple Final Cut Pro Legacy Capture Problems with Video Raid
  • Capture Problems with Video Raid
    Posted by Sebastian Martinez on May 30, 2007 at 7:14 pm
    Hey guys,
    regulary I’m capturing HDTV 1080i 50 at 8 bit 4:2:2 over a blackmagic brigde on a internal Video Raid on my Mac without any trouble. But just today, after I cleaned the raid from older stuff and after capturing DVCAM in RGB on it I had no chance to get any HD-material on the raid that is longer than 10 seconds. Reports of timecode errors. The tapes are ok, I used them before. The Raid seems to be fine except when I ran a speed test with blackmagic: 1 frame too slow.
    Does anyone of you know this problem or has an anwser?
    Thanks big times
    Sebastian
    Sebastian Martinez replied 19 years, 3 months ago 1 Member · 1 Reply
  • Sebastian Martinez
    May 31, 2007 at 3:53 pm
    Hey guys,
    ha, I found the solution myself by deleting all empty storage on the raid – so it says in german on the drive-assistant on the Mac. There are three version to overwrite deleted data wich was before various footage:
    1. Overwriting with zeros
    2. Deleting deleted date in 7 rounds
    3. Deleting deleted data in 35 rounds
    I tryed the first (but it took hours). Sounds wired but works! The speed test was now up at 43 fps for HDTV 1080i 50 8 bit an the material is capturing right now without a stop.
    It’s probably making a differences to iron the socks 😉
    Thanks for this site and keep on clickin’
    sebastian
