Activity Forums Apple Final Cut Pro Legacy Capture problems with Mac
  • Capture problems with Mac
    Posted by Kevin C. on May 28, 2007 at 9:36 pm
    I’m having massive problems capturing from FCP HD Express. I get the “detected dropped frames” after few seconds every time/ every tape.
    I’m plugged in directly to computer and even turned off preferece to abort on dropped frames!
    Someone has suggested that going to 10.4.9 (which I did) could be problem. Can anyone help me here? I’m all out of ideas thanks.
    Kevin C. replied 19 years, 3 months ago 4 Members · 5 Replies
  • Wally
    May 28, 2007 at 11:03 pm
    Try Snapz Pro. It gives you audio, video and stills. I’ve had great success with it.
  • 13 Create COW Profile Image
    13
    May 29, 2007 at 12:45 am
    [Wally] “Try Snapz Pro. It gives you audio, video and stills. I’ve had great success with it.
    he is trying to capture video from a tape not from the screen
    What type of hard drives are you use to capture the video to. Is it USB? USB drive cannot sustain a constant speed that is fast enough for video.
    You said that you are using Final Cut Express, this is the Final Cut Pro forum.
  • Kevin C.
    May 29, 2007 at 2:06 am
    thanks Z, hard drives are Firewire, they are new and good. there is not fcp express forum
  • David Roth weiss
    May 29, 2007 at 2:35 pm
    [kevin c.] “there is not fcp express forum”
    Yes there is!!!
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Kevin C.
    May 29, 2007 at 6:47 pm
    you get transferred to basic forum, but what would be great is if someone acutally helped with issue
