Activity Forums VEGAS Pro Capture Problems (ADVC300 & TBC)
  • Capture Problems (ADVC300 & TBC)
    Posted by Rick Hughes on February 8, 2010 at 8:47 pm
    Capturing a load of PAL SVHS tapes to DV AVI for edit with Sony Vegas, additionally using Vegas for the capture.
    Using the following set up ..
    P’sonic HS800 AVT 8710 ADVC300 PC
    I initially bought the ADVC300, then after reading many posts that say that this is NOT a full frame TBC, added the AVT 8710.
    Now I’m hitting trouble.
    Seen some very strange results – eg a VHS tape has an opening sequence of black, then some title text, after about 10 sec , a then second title screen, followed 10sec later by gradual fade in of video.
    If I play the tape .. this works fine.
    When I digitized it without TBC all digitized OK, however when I digitized with the 8710 in the path, the resulting capture has the first title screen OK, but when the second screen comes in the first stays .. so ends up with a text overlay mix.
    If I look at frames individually they are correct, but when I play the DV file it’s screwed ….. weird ?
    The rest of the video seems to have captured OK …
    but noticed some dropped frames.
    Thinking it something stupid … I cleaned video heads, and ran capture again … same thing?
    I only seem to be getting some frame loss when I use the 8710 compared to when it is not in circuit.
    Is there something I need to do here …………….. could there be interaction between 8710 & ADVC300 ? or is it something else?
    Do I need to turn anything off on ADVC300 ?
    John Rofrano replied 16 years, 6 months ago 2 Members · 1 Reply
  • John Rofrano
    February 9, 2010 at 2:22 pm
    Do you really need this? I capture old tapes with just my ADVC300 all the time without any problems with gaps in the tape or anything. Why not just use the ADVC300 alone if it’s working?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
