Activity Forums AJA Video Systems Capture Problems
  • Capture Problems
    Posted by Jeff Jeffares on June 28, 2008 at 12:58 pm
    Having capture problems using AJA Kona & DVD Pro 50. After I capture a clip, the clip does not show up in the browser. It is on the drive, but is not complete (small file size) and will not open in FCP or QT. It is happening with small 10-14 minute clips and full hour clips. I need help as I have 30 hours worth of tape to capture and I keep chasing my tail!
    Any suggestions? Thanks in advance.
    Jeff
    Jeff Jeffares replied 18 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    June 29, 2008 at 1:22 pm
    Post what your drive setup is, the version of FCP, OS, and QuickTime you’re running as well as the drivers for the Kona Card, and the deck you’re using to capture from. This is SDI with the deck controlled with RS-422, right?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Jeff Jeffares
    June 29, 2008 at 1:37 pm
    Thanks for the response Jerry,
    I was by myself in the office yesterday & needed some quick advice. We have narrowed it down to our 9TB G-RAID that we have on a 1G ethernet. Have moved to a local drive and the problem has cleared up. We have just moved into a new office and have not gotten everything up to speed yet. My tech is coming in Monday to straighten things out.
    Thanks again,
    Jeff
