Activity Forums Apple Final Cut Pro Legacy Capture problems
  • Capture problems
    Posted by Dennis Cornlenski on May 18, 2009 at 9:42 am
    I’m having a problem capturing a tape. Final Cut (Express) gives me the error: “Capture encountered a problem reading the data on your source tape. This could be due to a problem with the tape. Capture has been aborted and your clip has been saved.”
    However, when I play the tape everything is fine. I use a Sony DHR-1000VC to record the tape to Final Cut and it plays fine on that device.
    My question is: Is there a way to continue capturing even when Final Cut gives an error?
    The tape is quite important as it is part of an interview.
    Jeltje alexa Roetink replied 16 years, 9 months ago 5 Members · 5 Replies
  • John Fishback
    May 18, 2009 at 1:39 pm
    In User Prefs try unchecking “Abort capture on dropped frames.” Also, in Log & Capture you can try changing the Device Control selection to Non-controllable Device in the Capture Settings tab and using Capture Now instead of logging.
    Has L&C ever worked with this machine and a different tape? If so, there probably is something wrong with the tape, perhaps bad timecode, control track or dropouts.
    It never hurts to trash prefs and repair permissions.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Dino Vince
    May 18, 2009 at 3:15 pm
    I had this problem too, with an old Sony PD-150, turned out the heads needed adjustment. I turned off the ‘machine control’ and got around it for a while, then finally had to service the camera. Not sure what you’re using to capture, maybe you could try this. Good luck!
  • Jeltje alexa Roetink
    November 25, 2009 at 10:15 pm
    I have the same problem capturing a tape. Final Cut Express gives the error: “Capture encountered a problem reading the data on your source tape. This could be due to a problem with the tape. Capture has been aborted and your clip has been saved.”
    However, when I play the tape everything is fine. I use a Sony HDR-HC7E to record the tape to Final Cut Express and it plays fine on that device. Is there a way to continue capturing even when Final Cut gives an error?
    I already unchecked “Abort capture on dropped frames” but Final Cut Express still gives the same error when I try to capture. I also tried to capture from 3 other tapes and Final Cut Express continues to give the same error.
    I could not find the Log & Capture tab to try and change the Device Control selection to Non-controllable Device in the Capture Settings tab. Is that option available in Final Cut Express? And if so, could someone please explain me where to find it?
    And how can I turn off “Machine Control”. Could someone explain me where I can turn off “Machine Controle” please?
    To capture the tape is very important to me because it is part of my presentation for Friday.
    Thank you,
    Alexa
  • Rafael Amador
    November 26, 2009 at 7:01 am
    Hi Jetjel,
    Before trying “Uncontrollable device’, try setting (in the Preffs):
    – Check “On Timecode Break: Warn after capture”
    – Uncheck “warn when capturing
    To set the system to “Non Controllable Device” go to Audio/Video Preferences: Device Contol> None.
    rafael
    http://www.nagavideo.com
    November 26, 2009 at 1:21 pm
    Dear Rafael,
    Thank you for your kind respond.
    I’m sorry this may sound stupid. But under “User Preferences” I have 5 tabs: General, Editing, Timeline options and Render Control. Non of these items mention any options about the “Timecode Break”.
    Am I looking in the right place? Note that I use Final Cut Express and not FCP.
    Thank you for your time,
    Alexa
