Activity Forums Apple Final Cut Pro Legacy Capture problems
  • Capture problems
    Posted by Will Crowe on January 20, 2010 at 2:16 am
    I am using final cut express 4 which is typically very similar to final cut pro. I need to know how you make the clips divide individually when uploading in HDV. It all uploads as one giant clip and I know there must be a way to break it up by the timecode.
    David Bogie replied 16 years, 7 months ago 2 Members · 1 Reply
  • David Bogie
    January 20, 2010 at 3:36 pm
    [Will Crowe] “I am using final cut express 4 which is typically very similar to final cut pro. I need to know how you make the clips divide individually when uploading in HDV.”
    You’d want to be asking in the FCE forum. This isn’t in the FCE manual? Should be.
    bogiesan
