Activity Forums VEGAS Pro Capture problem-running out of room
  • Capture problem-running out of room
    Posted by Michael O’connor on January 31, 2012 at 10:25 pm
    I am working with v-7 Sony Vegas. I haven’t had this problem before so I can’t seem to fix it. I am capturing film to vegas as I always have, to a drive that has a little over 300 gb space available, but as I was capturing I could see the available recording time start to go way down until it hit 00:00:15;15. Now when I try to capture more film in disk management it tells me the capture file I am trying to go to is either full or does not exist?? But if I look at the graphic it shows the folder is 488 gb with 65% used. If I try to capture to that folder I get “warning: some disk management options may not work as expected. This feature is not configured properly”. I can get to where it lets me capture, but with only it showing only 00:00:15;15 it won’t record very long. I assume I have something set wrong. Any help you can give would be appreciated. Thanks in advance.
    Michael O’connor replied 14 years, 7 months ago 1 Member · 1 Reply
