Activity › Forums › Apple Final Cut Pro Legacy › capture problem due to OS 10.3.9?
  • capture problem due to OS 10.3.9?
    Posted by Mantrafilm on April 25, 2005 at 5:30 pm
    I encountered the same problem (audio out of sync) today while capturing and previewing from a Sony VX 1000 through firewire… (FCP 4.5) Never had that problem before; image and and sound were always in perfect sync. Checked my settings again, they were ok.
    I work on a dual processor G5. Could it be a bug in OS 10.3.9????
    David Bogie replied 21 years, 5 months ago 2 Members · 1 Reply
  • David Bogie
    April 25, 2005 at 8:10 pm
    If that’s the ONLY thing you changed recently, perhaps. But there’s nothing in 10.3.9 by itself that should be causing this. QT didn’t change, there was no update to your FCP apps, no change to the Firewire protocols. Umm, maybe the last one, dunno, just haven’t seen anything to suggest there was anything in the update that would affect how DV files are copied via FW. Safari and Java seem to be the major culprits
    You might want to cruise the geekier Macintosh OS sites for a few hours:
    https://www.macintouch.com/
    https://www.macintouch.com/panreader60.html#apr25
    https://www.tidbits.com/
    bogiesan
