Activity Forums AJA Video Systems Capture Problem (clips first 5 seconds)
  • Capture Problem (clips first 5 seconds)
    Posted by Chris Kelly on May 22, 2008 at 10:30 pm
    Hey guys,
    I’ve got a Kona LH on a Power Mac G5. I’m using Virtual VTR to capture. Strange problem capturing. Originally when I set this up, I had it capturing to a firewire drive. It captured fine, with the exception of it clipped off the first few seconds of the capture. So I tried capturing to the systems drive and it worked fine. Seeing as that worked, I figured the problem was the firewire. So I decided to capture the clip to the system drive, and have it auto push the file to the firewire drive after it was done capturing.
    Everything was great, except I really wasn’t excited about using the system drive as my capture, especially when we’re going to start capturing HD here pretty soon. DV isn’t too bad, but I don’t trust a capture that’s 4x the size.
    So I dropped a 1TB SATA on the 2nd SATA port of the G5… and I’m getting that stupid clipping of the first 5 or so seconds. Is there something that the system drive is doing that’s causing this problem? I tried the system test… and the 1TB drive is significantly faster than the system drive. I have the 1TB drive formatted HFS, but not journalled. Does that make a difference?
    Thanks in advance.
    Chris
    Chris Kelly replied 18 years, 4 months ago 2 Members · 2 Replies
  • Gary Adcock
    May 22, 2008 at 11:50 pm
    Have you contacted Mark Gilbert about this?
    not really a Kona issue – have you tried the AJA app called VTR Exchange?
    https://www.aja.com/ajashare/AJA_VTR_Xchangev3.tar
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Chris Kelly
    May 23, 2008 at 1:09 am
    I have talked with Mark before, but not on this issue. I may have brought it up with him, but stopped pursuing it because it worked on the system drive. I’ll contact him. Frankly, the reason I brought it up here was I thought it was an OS or hardware thing that someone may have run into here.
    Thanks for the help.
    Chris
