Activity Forums Apple Final Cut Pro Legacy capture problem between fcp hd and AJA Io
  • capture problem between fcp hd and AJA Io
    Posted by Dennis Allen on May 12, 2005 at 4:02 pm
    THIS MESSAGE APPEARS TWICE WHEN I TRY TO CAPTURE: Tape troube. Check VTR. Do not attempt to eject tape or use transport without checking VTR first. AND THEN THIS MESSAGE APPEARS: Capture Now has reached the end of the tape. All existing footage between the point where you started capture and the end of the tape was captured successfully.
    But it works fine when I use non-controllable device and CAPTURE NOW.
    Dennis Allen replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
