Activity Forums AJA Video Systems capture problem between fcp hd and AJA Io
  • capture problem between fcp hd and AJA Io
    Posted by Dennis Allen on May 12, 2005 at 4:04 pm
    THIS MESSAGE APPEARS TWICE WHEN I TRY TO CAPTURE: Tape troube. Check VTR. Do not attempt to eject tape or use transport without checking VTR first. AND THEN THIS MESSAGE APPEARS: Capture Now has reached the end of the tape. All existing footage between the point where you started capture and the end of the tape was captured successfully.
    But it works fine when I use non-controllable device and CAPTURE NOW.
    Jay Blanchard replied 21 years, 4 months ago 3 Members · 2 Replies
  • Videomansf
    May 12, 2005 at 11:16 pm
    The deck may be reporting a servo problem over 422 that its internal circuits are ignoring. Also some decks do this without a BBG or when in local and not remote. What deck are you using?
    Adam
  • Jay Blanchard
    May 18, 2005 at 3:39 pm
    Do you have continuous timecode on the tape? It sounds like there’s a timecode break. Or, if you’re starting from the beginning of the tape, are you starting your in point at least 20 seconds into the tape? I usually get the “end of tape” error because of pre-roll issues.
