Activity Forums Apple Final Cut Pro Legacy Capture problem…
  • Capture problem…
    Posted by Colin Williams on November 18, 2005 at 5:43 pm
    Hello All,
    I recently upgraded FCP from 4.5 to the new Studio Bundle (5.0). I am running on a G5 dual 2.5ghz and capturing with a Blackmagic Decklink SD card. For some reason, FCP is not recognizing the card, at all, as a capture device. I need to turn a spot around by the end of today and am clueless.
    The Blackmagic codecs are still available in the sequence settings, but no capture recognition at all.
    Please help.
    Thanks in advance.
    Cheers,
    Colin Williams
    http://www.pensivecrow.com
    Colin Williams replied 20 years, 10 months ago 1 Member · 2 Replies
  • Colin Williams
    November 18, 2005 at 5:52 pm
    Installing the new drivers to see if that helps…
    Stay Tuned!
    Colin Williams
  • Colin Williams
    November 18, 2005 at 6:18 pm
    Am I required to update to Tiger OS if I want to run FCP 5 with the Blackmagic drivers?
    Dilemma here.
    Colin Williams
