Activity Forums VEGAS Pro Capture Problem
  • Capture Problem
    Posted by Ozvideo on February 16, 2006 at 8:25 am
    When I try to capture video I can’t. When I look to see what options I have for capturing only the options for my Digital PC tuner card are listed that being a Compro DigiMate DBT-300. Where do I look to get Vegas capture to look for my Firewire card?
    Ozvideo replied 20 years, 6 months ago 3 Members · 4 Replies
  • Gary Kleiner
    February 16, 2006 at 3:59 pm
    Assuming that you have your device hooked up to your firewire port and it is recognized by the computer, you should see it listed when you click on the ‘video’ menu item at the top of the capture window.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Ozvideo
    February 17, 2006 at 7:25 am
    It doesn’t appear in Vegas at all. I then tried Windows Movie Maker which is part of XP & it captured it without a problem. Going back into Vegas again didn’t help. I mention this because I recently could not renderd to WMV so used Movie Maker & when I went back to Vegas it started working so using Movie Maker must have changed something, I have reinstalled Vegas but that didn’t help.
  • Edward Troxel
    February 17, 2006 at 3:29 pm
    Perhaps you’re using the wrong capture utility? Are you using the “Internal” or “External” capture? “Internal” is for HDV. “External” is for SD (i.e. MiniDV sources).
    Edward Troxel
    JETDV Scripts
  • Ozvideo
    February 18, 2006 at 1:01 am
    I’m using the same utility as always. Turn on camera when plugged into firewire port & windowws asks if I wish to capure using Vegas,Movie Maker etc. I choose Vegas which opens up but when I clcik to select capture devise only my PC tuner card is listed.
