Activity › Forums › VEGAS Pro › Capture Problem
  • Capture Problem
    Posted by Ralph Hajik on January 27, 2006 at 6:46 pm
    Hi Vegas Experts,
    I’m using Vegas 6c and trying to Capture my tape. It starts capturing and stops after 15 frames. It doesn’t want to continue on capturing. Under General I have checked “Enable DV Device” and under Capture I have checked “Unable DV scene detection”. Is this correct and then what do I need to do to have a complete capture. Any comments please.
    Ralph Hajik
    Ralph Hajik replied 20 years, 8 months ago 2 Members · 2 Replies
  • Gary Kleiner
    January 27, 2006 at 7:06 pm
    Are you transcoding an analog signal? If so, turn off DV device control.
    If not, disable ‘stop capture on dropped frames’.
  • Ralph Hajik
    January 27, 2006 at 7:55 pm
    Hi Gary,
    My disable on stopped frames is unchecked. Please ignore this posting. I have a couple of problems. First problem is my Dell P3. Apparently Vegas6c is to much for it to handle. My Capture dialog boxes freeze up and I have to reboot a lot or it’s a hardware problem. Second problem, I was getting atrifacts and noise in my footage after I had my Canon GL2 cleaned by Canon on the East coast. I couldn’t figure out what the problem was. I thought it was the Maxell tapes I use from Sam’s club. I never use a tape twice nor do I switch brands. I went to Sam’s and purchase a cheap JVC camcorder just to download my footage into Vegas6c. I played it back on the timeline and now I have no artifacts or noise. My problem has to be at the DV in/out connection port on my Canon GL2.
    Thanks for the quick response Gary
    Ralph Hajik
