Activity Forums Apple Final Cut Pro Legacy capture problem 24pAdvanced
  • capture problem 24pAdvanced
    Posted by Slade Baird on June 15, 2005 at 7:54 pm
    I am trying to capture footage shot in 24pAdvanced mode. When I batch capture, every time there is a break in timecode a new clip is created. Which is fine, but the problem is that the clips are randomly captured in at either 23.98 fps or 29.97. I’m pretty sure my settings are correct. I am capturing using the default 24p advanced pulldown option and my original footage frame rate is set to 29.97. I don’t understand why I would have clips with a 29.97 frame rate with these settings. Has anyone had a similar problem? This is the first version of FCP HD 4.5…is this a problem that was solved in an update?
    Mj Schirmer replied 21 years, 2 months ago 2 Members · 1 Reply
  • Mj Schirmer
    July 6, 2005 at 8:23 am
    We are experiencing a similar problem with SDX-900 footage shot at 24pa.
    I just completed a marathon import session over the weekend, spot checking occasionally.
    Now we go back to the footage files and there are maybe a fifth of the clips noted as 29.97 in FCP,
    while the rest are 23.98. Quicktime Player says the frame rates of the suspect clips are really 23.98. Cinematools has the pulldown removal button unavailable. If you go through these clips frame by frame there is no sign of interlacing. They appear to be 24p.
    It seems to me that FCP has somehow randomly corrupted these clips, flagging them as 29.97.
    Why do the other apps disagree on frame rate?
    The other strange thing is that the data rates of these clips are 5.7 mb/sec which is normal after Cap/pull down removal of a DVCPRO 50 clip at 24pa (raw 29.97 = 7mb/sec).
    One workaround has been to copy the contents of the clip in Quicktime and paste into a new movie, saving self contained and reimporting to FCP. This only worked on about half the clips so far.
    Those that it didn’t work for just keep importing as 29.97
    What is up with this? If we had dropped frames in our capture… wouldn’t FCP have stopped or segmented upon hitting a dropped frame. I need a solution quickly. Recapturing requires re-renting the DVCpro 50 deck, which we really don’t want to do again.
    PB 15″ 1.25ghz
    FCP 4.5
    QT 6.5.2
    Thanks for input,
    MJ SCHIRMER
