Activity Forums Apple Final Cut Pro Legacy Capture Problem
  • Capture Problem
    Posted by David Lewis on October 31, 2006 at 1:56 pm
    can’t see any data in my log-and-capture window. no video, no audio, no time code. but it’s there on the tape — I checked it in the camera. and the device control works, so I know the deck is communicating with FCP. what gives? I’ve had the same setpu- for years, never had this problem before. any suggestions?
    many thanks,
    Dave
    David Lewis replied 19 years, 11 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    October 31, 2006 at 1:59 pm
    See if iMovie see things correctly… if so it’s likely not a hardware (cable) problem.
    If iMovie works OK, try trashing preferences.
    If that fails, reinstall QuickTime 7… https://docs.info.apple.com/article.html?artnum=301852
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Lewis
    October 31, 2006 at 2:29 pm
    jerry, turned out to be dirty heads…~sheepish grin~…thanks for your help….
