Activity › Forums › Apple Final Cut Pro Legacy › capture old, OLLLLDDDDD 24p footage
  • Mark Suszko
    March 11, 2015 at 5:00 am
    I am as in the dark as you are. Tr fixing a sample section of what you’ve already captured, using compressor or cinema tools, and let’s see. Cinema Tools was made for just this kind of thing, if I recall correctly.
  • Keith Eyrich
    March 12, 2015 at 1:16 am
    So I opened a clip in Cinema Tools- clicked reverse telecine, and I “think” it looks better! And it saves it as a new file (.mov.rev) Now that new clip should be ready to be edited in Final Cut now, yeah? I’m just wondering what settings I should use in the reverse telecine pop-up menu (see attached screenshots) and also what capture settings I should use in FCP for optimal quality before running the clips through Cinema Tools to remove the jaggedy-ness. Thanks!
  • Mark Suszko
    March 12, 2015 at 3:54 am
    FCP 7 is most “comfortable” working in ProRes. I tend to use ProRes422 for most things in it.
    So, let us know if it’s “solved” after you’ve tried a sample of the new footage.
  • Keith Eyrich
    March 13, 2015 at 8:26 pm
    So for capturing I should use either of the 422 presets? Do I need to edit the presets at all to match the “24p” footage?
  • Keith Eyrich
    March 13, 2015 at 8:29 pm
    Will change to 23.98, and edit in 23.98 timeline! What should the frame rate be in my presets when I capture the rest of my footage?
  • Keith Eyrich
    March 20, 2015 at 4:52 pm
    The rest of the footage is the same, 24p of unknown variety. So do I need to set my capture preset to 23.98? Right now I’m just capturing at 29.97.
Page 2 of 2
