Activity › Forums › VEGAS Pro › Capture O.K, Printing Fails
  • Capture O.K, Printing Fails
    Posted by Mdg_nl on December 28, 2005 at 6:55 am
    I. have a very strange acting DV connection. Capturing from both my Sony and Panasonic DV camera works fine, but printing does always drop frames (every 10-30 secs a 0.5 sec of frames). When I use the same avi file in e.g. Pinnacle studio I can print to tape without any problem. What is wrong?
    Mdg_nl replied 20 years, 9 months ago 2 Members · 4 Replies
  • Edward Troxel
    December 28, 2005 at 2:38 pm
    Hard to say. Can you print from VidCap?
    Edward Troxel
    JETDV Scripts
  • Mdg_nl
    December 28, 2005 at 3:10 pm
    Hi Edward,
    I assume that you mean if I can print using the capture/printing tool that comes with Vegas. That is just what I’m doing all of the time. It allways drops frames when I rpint a rendered-as AVI file. I use it from the capture option in the file drop down list. Should I run it as an exe file without Vegas being active?
    Regards,
    Marcel
  • Edward Troxel
    December 28, 2005 at 4:56 pm
    [MdG_NL] “Should I run it as an exe file without Vegas being active?”
    That might not hurt.
    However, what about simply choosing Tools – Print to DV Tape in Vegas? Does that work? I assumed that was how you were going to tape and was offering the capture program as an alternative.
    Edward Troxel
    JETDV Scripts
  • Mdg_nl
    December 29, 2005 at 2:11 pm
    For an unknown reason I used the capture tool to try and print to tape. I guess it is because I used the capture tool first and saw that there was also a printing to tape option in it. It makes indeed more sense to use the Vegas-directly one. I will try this tonight and reply the result.
