Activity › Forums › AJA Video Systems › Capture offset question for new set up
  • Capture offset question for new set up
    Posted by Dan Riley on October 2, 2007 at 9:17 pm
    I’m capturing a DigiBeta A500. If I set the capture control preset to
    AJA Kona3: 29.97 Sony VTR B, it says the capture offset is -1.5.
    Minus 1.5 ??? Is this correct? It offsets a half a frame? A field if you will?
    And the playback offset is set to +00:00;01
    I did not set any of these. This is what came up after the installation.
    If I select:
    AJA Kona3: 29.95 Sony VTR A, it still has a capture offset of -1.5 frames
    but the playback offset is 0. Which Sony machines use the A VTR?
    To capture from our Panasonic AJ 455 I use the Panny seting which says
    it uses a -2.5 frame capture offset and no playback offset.
    This seems totally random to me. How does the AJA card know
    which Panny deck I’m using, or do all of them need 2.5 frames offset?
    With the AVID there is a setting for every type of VTR ever made it seems,
    but these setting look more generic.
    The reason I’m concerned is we will be doing offline/online stuff with tapes
    captured from other places, some from firewire, some from an AVID sequence
    that is translated via The DUCK, then recaptured from a batch list.
    If my settings are delaying the video relative to the timecode numbers
    this could be serious.
    What are the settings you guys are using for your decks?
    Dan
    Dan Riley replied 19 years ago 1 Member · 0 Replies
  • 0 Replies
