Activity › Forums › Apple Final Cut Pro Legacy › Capture Now Stopped due to lack of disk space on ethernet drive ?
  • Capture Now Stopped due to lack of disk space on ethernet drive ?
    Posted by Todd George on July 17, 2006 at 8:22 pm
    Hello all
    I am using FCP 5.1.1 on two seperate machines (two seperate seats of the software) both have access to a lacie ethernet drive (the drive is 2tb at the moment there are 1.6tb available) I am using the capture now feature which I have used in the past
    on the scratch disk tab for the system settings preference I have the scratch disk assigned to the lacie drive, it tells me there are 1.6tb available I also have the limit capture now check box UNCHECKED the min. allowable free space on the scratch disk is set to 2047mb(default)
    I have tried two seperate minidv programs(different sets of tapes) in two seperate minidv decks, on two seperate computers however EACH time I use capture now at the 9min mark both machines report back that capture now has stopped due to lack of free disk space yet the capture window shows 1.6tb of free space available
    now because I used two completely different tapes with material shot some 8 months apart I can’t accept a corrupt tape as an answer
    I used two different machines both of which accessed the drive via the ethernet connection (using the Go menu>connect to server…) both machines log onto the drive correctly and there is no problem with any of the media currently on the drive according to the drive info there are 172gb used and as I write this post I am able to see and hear video shot and captured to the drive just 4 days ago
    I tried trashing the fcp prefs but hit the 9min wall again
    my guess is a call to lacie may be the solution but perhaps some one on the forum could weigh in and offer a suggestion as well
    thank you in advance for you help
    take care
    btw running two G5 macs under the latest OS 10.4.7 both with a gig of ram one uses a sony dsr11 as a deck the other a jvc no problems with either prior to this and I have been able to capture material in excess of 1 hour to this drive through these machines less than a month ago
    Todd George replied 20 years, 2 months ago 5 Members · 10 Replies
  • 10 Replies
  • Bouncing Account needs new email address
    July 17, 2006 at 9:05 pm
    I’m not a big fan of “Capture Now”, it always seems a bit “iffy.”
    So I usually set an IN and OUT point and capture that way.
    BUT…
    Try actually SETTING a limit on “Capture Now” (say 30 minutes) and give that a try.
  • David Roth weiss
    July 17, 2006 at 9:13 pm
    Todd,
    What is the throughput on your ethernet drive? My guess is that the speed of that drive isn’t close to being good enough to for video capture. Ethernet drives, like USB drives are not meant as media drives. Perhaps playback works fine, but for capture, I don’t think so…
    DRW
  • Walter Biscardi
    July 17, 2006 at 9:21 pm
    [Todd George] “I am using FCP 5.1.1 on two seperate machines (two seperate seats of the software) both have access to a lacie ethernet drive (the drive is 2tb at the moment there are 1.6tb available) I am using the capture now feature which I have used in the past
    on the scratch disk tab for the system settings preference I have the scratch disk assigned to the lacie drive, it tells me there are 1.6tb available I also have the limit capture now check box UNCHECKED the min. allowable free space on the scratch disk is set to 2047mb(default)”
    Use Firewire 400, firewire 800, SATA or Fibre channel for your connection. Do not use Ethernet.
    Walter Biscardi, Jr.
  • Martin Baker
    July 17, 2006 at 10:57 pm
    The reason the capture is consistently stopping early is because you’re hitting a 2GB file size limit which just happens to be just over 9 mins of DV footage. AFAIK this is connected to the formatting of the disk and may or may not be fixable. As others have said, it’s just a bad idea to be using an ethernet disk for capturing.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! BigTIme – resizable timecode display for FCP
  • Walter Biscardi
    July 17, 2006 at 11:16 pm
    [Martin Baker] “The reason the capture is consistently stopping early is because you’re hitting a 2GB file size limit which just happens to be just over 9 mins of DV footage”
    there is no 2GB limit with Mac Formatted drives. I’ve done 30 minute Capture Now’s with 8bit SD and DV with no issues.
    If the drive is formatted for PC, then he would have an issue, though then the drive would most likely not work at all for FCP.
  • David Roth weiss
    July 17, 2006 at 11:21 pm
    Walter,
    But what is the format on an Ethernet drive??? Do you know? Do you know if an Ethernet drive can be reformated as a MAC drive? These are the issues Martin brought up.
    DRW
  • Walter Biscardi
    July 17, 2006 at 11:27 pm
    [David Roth Weiss] “But what is the format on an Ethernet drive??? Do you know? Do you know if an Ethernet drive can be reformated as a MAC drive? These are the issues Martin brought up.”
    I’m assuming an Ethernet drive can be formatted as either PC native or Mac Native. If it was left PC Native out of the box or was formatted PC Native, then it’s going to hit a 2GB file limit. We ran into that issue recently with an animated piece we did recently for an Avid editor. The animation was 3.5GB so we had to split the animation into two pieces.
  • Martin Baker
    July 17, 2006 at 11:38 pm
    Sure you can capture 2GB+ clips to Mac formatted disks but I didn’t say you couldn’t! As for PC formatted drives, FCP doesn’t care until you hit 2GB file size and then things fall apart as they have done in this case. The 9 minutes was a clue.
    Martin
  • David Roth weiss
    July 17, 2006 at 11:47 pm
    From a review on the Lacie site:
    One interesting option I noticed was the disk format menu (Figure 4). By default, the mini’s internal disk is formatted in a least-common-denominator format of FAT32 so it can be directly accessed when USB-plugged into a Windows, Macintosh, or Linux system. But one downside to FAT32 is a file size limitation of 2GB.
    To get around this limitation, the mini allows you to reformat the disk with a Linux ext3 filesystem that supports larger files, albeit with reduced portability. For example, if you format the drive with ext3, you will no longer be able to use the mini as a USB external drive under Windows or Macintosh. It will still be usable as a network drive under all systems, you just won’t be able to directly plug it into the USB port of a Windows or Macintosh system. While this isn’t ideal, it at least gives options to users who need support for files over 2 GB.
  • Todd George
    July 18, 2006 at 2:25 pm
    Hello all
    first off thanks to everyone for your insight …. I do remember reading about the 2gb limit a year or two ago
    anyway we left the lacie drive pc formatted (default) because at some point down the line we may want to have a pc network into the video files and allow one of our student work study employees to work with the media files on premiere so it seems like we’ll have to capture video on the machines locally and upload the files to the ethernet drive
    just out of curiosity, are any of you out there using large storage drives like this in your workflow perhaps you have some tips and tricks to share
    again thanks to everyone
    take care and keep cool as someone told mother nature it was summer in north east ohio and she is kickin ass
    Todd George
    Instructional Media Services
    John Carroll University
    University Heights, OH 44118
