Activity Forums Apple Final Cut Pro Legacy Capture Now issues
  • Capture Now issues
    Posted by Joseph Bradley on December 10, 2008 at 4:48 am
    I have a MacPro running FCP 6.0.4 and a Kona card to capture. I do both HD and SD. The system has been running fine for months and suddenly when I go to capture from the HD deck doing Capture Now it won’t register the video right away( about five seconds)and it looks horrible, like it was trying to see the tape but couldn’t, but will start capturing the audio causing the clip to be way out of sync. If I do a batch capture I don’t have this problem and if I capture from the Digibeta deck I don’t have any problems no matter how I capture. The only thing I have done differently is I have been trying to get compressor to work over a remote cluster for DVD compression, which hasn’t worked yet, and I had been working on that for about four hours. but nothing changed in FCP. Capture Now is my normal work flow since I get 30 minute tapes that are from locked down cameras creating one long clip.
    It’s driving me crazy so if anyone has any ideas I would appreciate it.
    Joseph
    Joseph Bradley replied 17 years, 9 months ago 3 Members · 14 Replies
  • 14 Replies
  • Bill Dewald
    December 10, 2008 at 4:54 am
    Have you trashed your preferences? I find that corrupt prefs often to weird things to the log and capture module.
    Also, double check the settings in your AJA app.
  • Joseph Bradley
    December 10, 2008 at 5:12 am
    Thanks for getting back so quick, Bill. I did trash the prefs several times and the settings in the Kona card seem ok, but maybe I should trash those prefs as well. It’s worth a try.
  • Bill Dewald
    December 10, 2008 at 5:14 am
    While you’re trying, perhaps try re-installing the Kona drivers.
    Don’t be afraid to try AJA tech support. They’re wizards. I know it.
  • Jeremy Garchow
    December 10, 2008 at 5:22 am
    Are you capturing VFR from a Varicam by chance?
    What easy setup and codec?
  • Joseph Bradley
    December 10, 2008 at 5:28 am
    We are using a Panasonic 1400 HD deck.
  • Joseph Bradley
    December 10, 2008 at 5:29 am
    Interesting thought. And you are right, AJA has a fantastic support staff.
  • Jeremy Garchow
    December 10, 2008 at 5:31 am
    And are you trying to remove redundant fames (VFR is Variable Frame Rate). For example, are you capturing 720p24 or 720p30? If so, you need to log and capture to do this and can’t capture now due to the Kona needing to properly read and remove the VFR cadence from the tape.
    If you capture 720p60, you will be able to capture now.
    Make sense?
    Jeremy
  • Joseph Bradley
    December 10, 2008 at 6:11 am
    Thanks for the thoughts Jeremy but I’m not capturing Veriable rates. I’m doing 1080i 29.97.
    Joseph
  • Jeremy Garchow
    December 10, 2008 at 6:21 am
    Okay, are you sure your deck is setup as such? And your using a 1080i29.97 easy setup?
  • Joseph Bradley
    December 10, 2008 at 6:27 am
    Absolutely, everything by the book.
