Activity Forums Apple Final Cut Pro Legacy Capture Now borken?
  • Capture Now borken?
    Posted by Dave Kulawick on February 16, 2006 at 3:52 pm
    OS 10.3.9, FCP HD 4.5
    Capture Now is limited to 32 minutes, but FCP is still reserving filespace out to the entire drive. I do the capture, and then wait for the beach ball to come off, which sometimes is taking longer than the duration of the actual capturing!
    After the capture, and while I wait for the beach ball to go away, I can see this
    [IMSBigMac:~] editor% ls -la /Volumes/MediaDrive02/Final\ Cut\ Pro\ Documents/Capture\ Scratch/FCP_Captures/
    total 20087888
    drwxrwxr-x 23 macadmin staff 782 16 Feb 09:42 .
    drwxrwxr-x 13 macadmin staff 442 14 Feb 09:05 ..
    -rw-rw-r– 1 macadmin staff 2047941952 16 Feb 10:10 Akwasasne-av
    -rw-rw-r– 1 macadmin staff 2047942848 16 Feb 10:10 Akwasasne-av-1
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:29 Akwasasne-av-10
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:31 Akwasasne-av-11
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:34 Akwasasne-av-12
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:37 Akwasasne-av-13
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:39 Akwasasne-av-14
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:42 Akwasasne-av-15
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:44 Akwasasne-av-16
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:47 Akwasasne-av-17
    -rw-rw-r– 1 macadmin staff 314613760 16 Feb 09:42 Akwasasne-av-18
    -rw-rw-r– 1 macadmin staff 2047939648 16 Feb 10:10 Akwasasne-av-2
    -rw-rw-r– 1 macadmin staff 331067136 16 Feb 10:10 Akwasasne-av-3
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:13 Akwasasne-av-4
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:16 Akwasasne-av-5
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:18 Akwasasne-av-6
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:21 Akwasasne-av-7
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:24 Akwasasne-av-8
    -rw-rw-r– 1 macadmin staff 4096 16 Feb 10:26 Akwasasne-av-9
    If I’ve limited Capture Now to 32 minutes, why is there a “Filename-av-7”. 32 minutes should be ~ 7 GB, or at the most 4 AV files limited to 2 GB each. What’s going on?
    Yes, I’ve trashed prefs, and run DiskWarrior on the capture drive, which is an internal IDE with over 30 GB of free space. Any ideas?
    TIA
    dbk
    Kevin Monahan replied 20 years, 7 months ago 4 Members · 3 Replies
  • Debe
    February 16, 2006 at 4:54 pm
    How is the drive you are capturing to formatted?
    Have you repaired permissions lately?
    debe
  • Shane Ross
    February 16, 2006 at 7:48 pm
    Do you have Virex installed? That causes issues too.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Kevin Monahan
    February 16, 2006 at 8:36 pm
    No, Debe’s right I bet. Your drive is not initialized properly. You’ll need to use Disk Utility and rewipe that drive. Ummm, I betcha it’s a brand-spankin’-new FireWire drive, no? Any NEW drive MUST be re-initialized regardless of what is says on the box about being Mac friendly.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
