Capture logging issue – Could be a Bug?
I have no trouble capturing the footage from my device,
however when i press ‘escape’ to stop the capture at the time i want, the clip does not appear in my browser bin??
The clip is being captured though in the capture scratch folder, so i end up having to import the clip into the bin.
It seems the link to the clip in the browser bin does not want to appear.
I have tried several setting changes and scratch disk options to nut out the problem and have had no luck?
please help if you have experienced the same problem and know the solution
Regards
Adam
PS: many thanks to the genius to figure this one out.
