Activity Forums Adobe Premiere Pro capture limit
  • capture limit
    Posted by Peter on April 3, 2006 at 7:50 am
    hi there
    i did a batchlist, and now when i want premiere to digitize these offline clips it doesnt work, the script, which appears in the window sais(in mi translation):
    digitizing failed, filelimit reached,batchcapturing endet
    where do i set the limit for the clips? (got enough discspace)
    thx in advance
    peter
    Peter replied 20 years, 5 months ago 3 Members · 5 Replies
  • Mike Velte
    April 3, 2006 at 11:44 am
    Assuming you are using a generic OHCI firewire capture, you may have FAT 32 as the file system for your target drive. This will limit your capture to about 18 minutes. In My Computer, right click on that drive and choose Properties. What file system does it show?
  • Peter
    April 3, 2006 at 9:01 pm
    jep thats right, fat 32, but does that mean, that there is no possibilitie to capture this way?
    also its not possible to capture this file on another hard disc and copy it to this one, right?
    thx
    peter
  • Mike Velte
    April 4, 2006 at 11:48 am
    You can easily convert your file system to NTFS. Move all the files to another drive, then in My Computer, right click on the drive and choose Format. Select NTFS as the file system and also Quick Format.
  • Dave Friend
    April 4, 2006 at 12:40 pm
    Peter,
    You can convert the drive to NTFS easily using the Windows utility convert.exe
    You do not have to reformat drive or move the files currently on the drive.
    See this link for more information.
    https://www.microsoft.com/technet/prodtechnol/winxppro/maintain/convertfat.mspx
    Hope this helps.
    Dave
  • Peter
    April 5, 2006 at 10:57 pm
    thank u veri much!
    peter
