Activity Forums Adobe Premiere Pro Capture Issues with 1.5
  • Capture Issues with 1.5
    Posted by Chris Holland on January 26, 2006 at 2:54 pm
    I know this has been broached before and I am going to post this in the Premiere Forum as well but I have never seen or found a definitive answer on this and I am still having Timecode sync issues with my Beta Deck when capturing.
    Here is the setup:
    1. Pulling Footage from a Beta Deck
    2. Using a DA-MAX+.
    3. Canopus DV Storm 2 Card
    4. Using a Patch Panel to connect the Beta Deck (UVW-1800) to the DA-Max+
    The issue is this:
    The timecode in my capture window is anywhere between 3-5 seconds off of what the Beta Deck is showing. (It is different everyday, sometimes there is no discrepency). So when I mark an in it will be at the time in the capture window. Once I try to capture the clip the Capture Window and Beta Deck then sync up. So the problem is now it starts recording 3-5 seconds later than I actually marked in at.
    Has anyone seen this problem and found a solution to it. It is extemely annoying.
    Also, just and FYI but we have a sync generator and it doesn’t help with this issue.
    Any thoughts would be appreciated. Thanks.
    Chris Holland replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
