Activity Forums Apple Final Cut Pro Legacy Capture Issues in FCP 5
  • Capture Issues in FCP 5
    Posted by Rowland Bestwina on May 19, 2009 at 11:35 pm
    I am receiving an error message when I launch AND try to capture video in FCP 5. The error msg reads: “Unable to initialize video deck. You may still log offline or use capture now.” I took someones earlier advice on another thread and changed my settings to non-controlable Device and tried doing Capture Now but it still does not work. Any ideas? I am wondering if it has something to do with my deck or cable. I’m simply using a dv cam as my deck… or is it a setting on my G4 867 Dual Processor. I am still able to edit and have full functionality of FCP. I can get by for now since I have a project I am working in with media already on my computer BUT I would love another means of bringing in the video other then having to burn it to dvd and use MPEG Streamclip to convert it. Any help would be greatly appreciated!!! Thank you in advance… ~Rowland
    Tom Wolsky replied 17 years, 3 months ago 3 Members · 6 Replies
  • Richard Harrington
    May 20, 2009 at 3:22 am
    Umm…
    Ever think of sharing a little info about WHAT deck you have and HOW its connected.
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • Rowland Bestwina
    May 20, 2009 at 3:32 am
    Sorry… so caught up in the moment…. the deck I am trying to use is my DV Cam via firewire. I use to be able to use the DV Cam fine when I was using 4.5 HD… I installed an upgrade to 5.04 and now I get the error message “cannot initialize deck…etc.”. Any thoughts on this? Thank you in advance!!! ~Rowland
  • Rowland Bestwina
    May 20, 2009 at 5:37 am
  • Tom Wolsky
    May 20, 2009 at 12:46 pm
    This is completely inadequate.
    Please give your full system specifications, what computer, what drives, what camera or deck, how everything’s connected, what settings are on the media, what settings you’re using in Final Cut, and finally what version of the software, of the OS, and of QuickTime you are using.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Rowland Bestwina
    May 20, 2009 at 7:20 pm
    Hi Tom,
    Thank you for your interest in helping me out! Much appreciated!
    Sorry for the inadequate information… here are the specs you requested:
    I am using a:
    *Machine Name: Power Mac G4
    Machine Model: PowerMac3,6
    CPU Type: PowerPC G4 (2.1)
    Number Of CPUs: 2
    CPU Speed: 867 MHz
    L2 Cache (per CPU): 256 KB
    L3 Cache (per CPU): 1 MB
    Memory: 2 GB
    Bus Speed: 133 MHz
    Boot ROM Version: 4.4.8f2
    Chipset Model: GeForce4 MX
    Type: Display
    Bus: AGP
    Slot: SLOT-1
    VRAM (Total): 32 MB
    Vendor: nVIDIA (0x10de)
    Device ID: 0x0172
    Revision ID: 0x00a5
    ROM Revision: 1121
    Displays: L206W:
    Resolution: 1280 x 960 @ 75 Hz
    Depth: 32-bit Color
    Core Image: Not Supported
    FireWire Bus:
    Maximum Speed: Up to 400 Mb/sec
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Quartz Extreme: Supported
    ATA Bus:
    Maxtor 6Y120P0:
    Capacity: 114.5 GB
    Model: Maxtor 6Y120P0
    Revision: YAR41BW0
    Serial Number: Y4144JFE
    Removable Media: No
    Detachable Drive: No
    BSD Name: disk2
    Protocol: ATA
    Unit Number: 0
    Socket Type: Internal
    OS9 Drivers: Yes
    S.M.A.R.T. status: Verified
    Volumes:
    Maxtor 120:
    Capacity: 114.5 GB
    Available: 3.73 GB
    Writable: Yes
    File System: HFS+
    BSD Name: disk2s9
    Mount Point: Volumes/Maxtor 120
    Maxtor 6Y160P0:
    Capacity: 152.67 GB
    Model: Maxtor 6Y160P0
    Revision: YAR41VW0
    Serial Number: Y60LVRHE
    Removable Media: No
    BSD Name: disk1
    Protocol: ATA
    Unit Number: 1
    OS9 Drivers: Yes
    Volumes:
    Maxtor 160:
    Capacity: 152.67 GB
    Available: 16.72 GB
    Writable: Yes
    File System: HFS+
    BSD Name: disk1s9
    Mount Point: Volumes/Maxtor 160
    I am also using an external a 875 gig Lacie Drive.
    Mac OS 10.4.11
    Final Cut Pro: V. 5.04
    Project Settings:
    720/ 480 DV/ DVC Pro NTSC
    Compressor: DV/ DVC Pro NTSC
    Deck: Mini DVD Cam
    I didn’t have this issue with FCP 4.5 HD… once I upgraded it won’t let me initialize the deck or allow FCP to even see the DV Cam deck.
    I hope I gave you enough to go on. 🙂
    Thank you for all your help Tom!!!
    ~Rowland
  • Tom Wolsky
    May 20, 2009 at 9:18 pm
    Your version of the software is too old for the OS and QT version you’re using. You will need to return to 10.4.10 or earlier and QuickTime versions prior to 7.3.
    All the best,
    Tom
