Activity › Forums › Apple Final Cut Pro Legacy › Capture issue Yikes!!!
  • Capture issue Yikes!!!
    Posted by Roy Schneider on January 23, 2010 at 9:12 pm
    Hi All:
    I have a client that brought me some DV tapes to capture and create a DVD. There is video on the tape, but the signal looks like it is breaking up a bit. When I try to capture it kicks out and says there is a signal problem. I tried play and capture with the same result. Any ideas about getting this into the system.
    Thanks for your thoughts.
    Roy
    Roy Schneider
    Long Live Da Cow!
    John Pale replied 16 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • John Fishback
    January 23, 2010 at 10:29 pm
    How are you capturing the tapes? Camera, deck? Describe your system and workflow so it’s easier for folks to help you out.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Don Walker
    January 23, 2010 at 10:32 pm
    Roy,
    is it possible that the tapes are recorded on a Consumer camcorder in LP mode, and your playing them back on Professional deck that can only handle SP mode. That would be the first thing I would look at.
    The remedy for that problem would be to use the camera that they were shot on to do your capture. Another possibility would be that the heads were either dirty or clogged on the recording camera, or on your playback machine. Run a cleaning tape (one would of come with your deck) and see if that fixes the problem on the playback side. ( if the problem was on the record side you are out of luck) .
    Don Walker
    John 3:16
  • John Pale
    January 23, 2010 at 11:08 pm
    Could also be DVCAM or DVCPRO trying to be captured on a deck that can only play DV.
    Need more info.
  • Roy Schneider
    January 23, 2010 at 11:16 pm
    Hi All Thanks for the responses. I am using a dv camera via firewire into a g-raid. Final Cut pro is running on brand new IMAC I-7. . It is not the camera that captured the tapes originally. I cleaned the heads on my camera. The tapes are a transfer from 8mm film, but could have been a screen shot. could be an SP-LP thing. Is there anyway I can tell?
    Picture in getting digital lines on the left and right sides. Looks like interlacing of the fields.
    Thanks again!
    Roy
    Roy Schneider
    Long Live Da Cow!
  • Steve Eisen
    January 24, 2010 at 2:39 am
    Could be a variety of things. Alignment problem, bad tape, SP-LP, etc.
    If you hit display on your DV camera, what shows up? DV 48K. DV 32K? SP?
    You might need to capture from the camera/deck the original was recorded, if at all possible. If not, try a different camera/deck.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Roy Schneider
    January 24, 2010 at 2:52 am
    Hi Steve:
    Thanks for your help. playback says 48K SP.
    Roy
    Roy Schneider
    Long Live Da Cow!
  • John Pale
    January 24, 2010 at 6:36 pm
    I am guessing it was recorded in DVCAM or DVCPRO. They can be recorded on regular miniDV tape, and will play in a miniDVcamera/deck, but with visual distortion.
    Can you ask who gave you the tape what was used to record it?
