Activity › Forums › Adobe Premiere Pro › CAPTURE IN REVERSE
CAPTURE IN REVERSE
Posted by Willie Toth on June 19, 2006 at 12:16 pmIs there a way to either capture in reverse and or make a clip play in reverse in Pre Pro … I am using 1.5 ………. WILLIE
Labrisher replied 20 years, 3 months ago 3 Members · 3 Replies -
Lloyd Coleman
June 19, 2006 at 1:37 pmYou can make the clip play in reverse by doing this: With the clip on the timeline, right click with the mouse, select ‘Speed/Duration” from the pop-up menu, select the “Reverse Speed’ box. If you want the clip to play at regular speed in reverse, leave the “Speed” at 100%, or you can change the speed the clip will play by adjusting the number in the “Speed” area.
Labrisher
June 19, 2006 at 9:11 pmIf there’s an audio track associated with the video, don’t forget to unlink them otherwise the audio also gets played backwards – unless that’s the effect you want too.
