Activity Forums VEGAS Pro CAPTURE HELP!!!!!
  • CAPTURE HELP!!!!!
    Posted by Weymar Bozo on December 1, 2007 at 2:06 am
    I have just upgraded to Vegas Pro 8. Everything works fine except one thing. I was at a shoot a couple days ago and trying to capture footage from the camera through firewire. Using videocapture60. I was unable to capture ANY footage. The software prompted me to insert a tape. I didnt want to capture from the tape, I wanted to capture from the camera. This feature worked fine with Vegas 7. Can someone please help?? I have contacted Sony with no response…:( and I def. dont want to downgrade.
    Thanks in advance,
    wb
    Mike Kujbida replied 18 years, 9 months ago 2 Members · 3 Replies
  • Mike Kujbida
    December 1, 2007 at 12:29 pm
    Options – Preferences – General.
    Make sure Enable DV device control is NOT selected.
  • Weymar Bozo
    December 1, 2007 at 3:20 pm
    Thanks man, that worked. For some reason Videocapture 60 only captures DV and not HDV. I wonder what the deal with this is. I was able to capture HDV within Vegas though. Thanks again.
  • Mike Kujbida
    December 2, 2007 at 4:05 am
    VidCap 6.0 works fine, but it doesn’t do HDV.
    You have to switch back and forth from internal to external capture in the preferences (Options – Prefs – Video).
    Doing this brings up the other capture window which will allow you to select HDV.
