Activity Forums Apple Final Cut Pro Legacy Capture HDV without timecode?
  • Capture HDV without timecode?
    Posted by Alex Grybauskas on July 24, 2008 at 2:44 pm
    Hey,
    First time working with HDV. It’s for a multicam concert shoot, and a couple of the tapes have massive time code breaks (director thinks it was a problem with one of the cameras). When that happens on DV I’ll switch to non-controllable device and capture without timecode, but when capturing HDV I don’t have that drop-down menu anymore in the capture Settings tab of the capture window. Is there anyway I can capture these tapes without timecode, or is there some workaround? It’s breaking the tapes into dozens of small clips which would be hell to edit
    Chris Poisson replied 18 years, 2 months ago 2 Members · 1 Reply
  • Chris Poisson
    July 24, 2008 at 8:05 pm
    Alex,
    What I do is let it do it’s thing, then go through each clip from that tape and in the browser, change the name of each clip, or toss it. There’s a right click that gives you the option to rename the master clip in your capture scratch.
    Otherwise, make a dub of the tape.
    Even if you could capture without timecode, that would still not fix your problem that I can see.
    Have a wonderful day.
