Activity › Forums › Apple Final Cut Pro Legacy › Capture HD
Capture HD
Posted by Maurice Van bavel on July 18, 2008 at 6:44 pmI have a JVC GY-HD100 camera and a player JVC BR-HD50. In DV there are no problems. But in HD the capturing from the camera or player stops on every cameastop, saying: “Searching for media” and start again after 5-6 sec. So I mis images.
Do I somthing wrong in “preferences”?
Sorry for my bad EnglischMaurice Van bavel replied 18 years, 2 months ago 3 Members · 5 Replies -
Michael Gissing
July 18, 2008 at 11:52 pmIn the capture window there is a default selection on one of the tabs to break capture on every camera stop. It should by default be deselected as it is, by general consensus, not desired. Instead you need to find this and deselect it.
I don’t have my FCP open at the moment so I can’t be more specific.
Maurice Van bavel
July 19, 2008 at 7:13 pmThanks for help Michael but in the “Log and Capture” window I only see in the “Capture Settings” tab : “Scratch Disk…” and after that: the free space in time and GB.
Walter Biscardi
July 19, 2008 at 7:16 pmAre you in an HDV Easy Setup? Doesn’t sound like you are. The Log and Capture window looks completely different for HDV capture and the button Michael is talking about is there.
[Maurice van Bavel] “Thanks for help Michael but in the “Log and Capture” window I only see in the “Capture Settings” tab : “Scratch Disk…” and after that: the free space in time and GB. “
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Maurice Van bavel
July 19, 2008 at 8:02 pmThe settings are:
Easy Setup: Format: HDV
Use : HDV-720p25
Rate : 25 fps
The information tells me:
Sequence Preset: HDV-720p25
Capture Preset: HDV
Device control Preset: HDV Firewire 25 fps
…. etc.My software is Final Cut Studio 2
Maurice Van bavel
July 21, 2008 at 3:53 pmIt will not work.
Not with my player BR-HD50, not with my camera GY-HD100E.
Not with “Capture now”, not with “log clip”.
Not with “Create new clip on Start/Stop” on or off.
Perhaps because it is “PAL”.
My FCP is version 6.0.4
So I think there is no solution for my problem.
Thank to all.
