Activity Forums Apple Final Cut Pro Legacy Capture from XDCam HD?
  • Capture from XDCam HD?
    Posted by Per Rönnecke on November 6, 2007 at 9:27 pm
    Hi!
    I’m working with XDCam HD (the camera is a 330) and FCP 6 and usally we are using the transfer software to transfer files from the camera.
    Now I have one disc with a proxyfile that seems to be corrupt. It, crashes the transfer program.
    Today I tried to capture through Log and Capture in FCP and firewire with the camera in AV/C mode, but I didn’t find any settings in FCP that worked.
    Is this possible to do? If not, is there another way to get around the corrupt file?
    /Per
    Per Rönnecke replied 18 years, 10 months ago 5 Members · 7 Replies
  • 7 Replies
  • Gary Adcock
    November 6, 2007 at 10:26 pm
    [Per W. R
  • Per Rönnecke
    November 6, 2007 at 10:33 pm
    No, picture, no device control!
    /Per
  • Gary Adcock
    November 6, 2007 at 11:00 pm
    [Per W. R
  • Steve Connor
    November 7, 2007 at 9:30 am
    Don’t quote me on this but I don’t think you can capture 35mb Xdcam HD through firewire. You can only capture 25mb XDCam HD.
  • Alan Lacey
    November 7, 2007 at 10:26 am
    I’m sure you’re right Steve. I reckon the only way Per would be realtime capture via SDI.
    Alan
  • Mark Maness
    November 7, 2007 at 3:38 pm
    You’ll have to hook up the camera using Analog Component and connect the RCA audio out to your capture card and use the firewire as machine control. The 330 camera doesn’t have SDI out on the camera. Sorry…
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Per Rönnecke
    November 7, 2007 at 6:04 pm
    Thanks! This is what I suspected. And the Kona 3 card doesn’t have analog component so that’s not a solution. And there is no deck or drive available close to here.
    Does anyone know how to deal with a corrupt proxyfile? It crashes the transfer program, but we have imported it to a PC with the proxy browsing software, so it’s not totally damaged.
    I’ve read about the new transfer software somewhere that you can disable proxy import. Could that be a solution?
    /Per
