Activity › Forums › Apple Final Cut Pro Legacy › Capture from non-contollable device with timecode
  • Capture from non-contollable device with timecode
    Posted by Will Kinder on March 19, 2009 at 12:32 pm
    Hi
    Here’s my situation: (FCP 6)
    I have a multi cam shoot with all DSR cameras locked to timecode. This is also recorded on the master DV deck. In addition I also capture the master mix straight into FCP using the ‘non-controllable device’ setting via the deck’s firewire.
    The problem is that in doing this, FCP does not take in the master timecode but instead generates it’s own, which is a problem when trying to sync up clips from the camera ISOs later in the edit.
    I’m told there is no software solution to this, but there might me a gadget that enables you to re-feed master timecode back into FCP?
    Any thoughts on the gadget or work-arounds?
    Will
    Will Kinder replied 17 years, 6 months ago 2 Members · 2 Replies
