Capture from a Vestax PBS-4
Hello
I’m trying to capture footage from a Vestax PBS-4 using Final Cut Pro.
Does anyone know if this is possible and how to do it?
I’m using Final Cut Pro 7 on a MacBook Pro running OSX 10.8.3.
I have tried customising the Capture Presets but get the error message ‘Codec not found. You may be using a compression type without the corresponding hardware card’.
When I try to log and capture, video from the PBS-4 shows up in the Capture window, but when I try to catpure the footage I get the error message ‘Attempt to capture video without a video device selected. Please select a video device in your capture presets and try again.’
Any advice appreciated.
Darren
