Activity Forums Adobe After Effects Capture Frame
  • Capture Frame
    Posted by David Yowell on April 2, 2009 at 6:01 pm
    I would like to know how to capture the last frame of my project so that I can edit it with Illustrator. I know that you can export to Photoshop, but is there a way to export the frame as a JPEG? I am using AE CS3. Thanks in advance for the help.
    Kevin Camp replied 17 years, 5 months ago 2 Members · 1 Reply
  • Kevin Camp
    April 2, 2009 at 6:18 pm
    just go to the last frame in the comp and choose composition>save frame as>file. that will send the comp to the render queue. click the output module (should say ‘photoshop’) and change the format from photoshop sequence to jpeg sequence, set your file path and hit render.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
