Activity Forums Apple Final Cut Pro Legacy Capture follows project…
  • Capture follows project…
    Posted by Chris Kelly on June 23, 2006 at 10:02 pm
    Forgive the noob question here. For years I used PPro, and love the feature to be able to capture to the folder the project was in. We have 3 FCP5 boxes that we’re going to connect via a common server. We’d like to just be able to edit straight off the server. I did some searching around and I’m afraid I already have the answer (that I don’t want) but I just want to confirm it.
    Is there a way to tell FCP to capture to the folder that the project is contained in?
    Obviously, we’d like to work completely off the server… and if all that is on the server is the footage, with no projects… the other editors can’t really do much. Thanks for the help.
    Chris
    Walter Biscardi replied 20 years, 2 months ago 2 Members · 1 Reply
  • Walter Biscardi
    June 23, 2006 at 11:43 pm
    [christopherk]
    Is there a way to tell FCP to capture to the folder that the project is contained in?”
    Sure, just set your Capture Scratch to the Project Folder. This can cause slowdowns if you have too many Folders in Folders, but it does work. Better to just point to the harddrive and let FCP assign the folders.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
