Activity Forums VEGAS Pro Capture Folders
  • Capture Folders
    Posted by Mac Mcginnis on December 11, 2007 at 2:38 am
    While capturing a project I maxed out the folder the clips were being captured to. I added another folder in the other partition of the hard drive that had space since the other partition was full. Will this be a problem when I try to render? Is it best to pull the files into one folder before I go further or can it render from two different locations. I’m a newbie and never came across this before. Most of my projects weren’t this large.
    Edward Troxel replied 18 years, 9 months ago 3 Members · 2 Replies
  • Mike Kujbida
    December 11, 2007 at 4:10 am
    My guess (and I hope I’m wrong) is that you’re capturing to your system drive (even if it’s partitioned).
    This is a mistake as all that should be on this drive is your OS & your programs and nothing else.
    Hard drives are so cheap these days that a 2nd (or 3rd or more) makes a lot of sense.
    My system has 3 drives, C (200 GB.) is the OS & programs, D (500 GB.) is the capture (and other assets) drive and E (500 GB.) is the render drive.
    Doing things this way speeds up your renders and is much easier on the system.
    To answer your original question, you can do it your way but it’s not the best way to edit 🙁
  • Edward Troxel
    December 11, 2007 at 2:43 pm
    [Mac McGinnis] ” Is it best to pull the files into one folder before I go further or can it render from two different locations.”
    It doesn’t matter where the source files are located. When you render, it can find them on whichever drive they’re located.
    Edward Troxel
    JETDV Scripts
