Activity Forums Adobe Premiere Pro Capture File Compression
  • Capture File Compression
    Posted by Jerry Kemp on April 22, 2013 at 1:39 am
    I am editing with Adobe CS4. I am capturing video from a DVCPro tape using a Blackmagic capture card for a television ministry.
    However, the video file that results from the capture is a 30 GB .avi file. When I try to edit this, and combine clips from another video I run into some problems that appear to be resource related.
    I believe the root cause may be the large file sizes I am dealing with.
    Is there a setting I am overlooking that would allow the captured file to be in a compressed format rather than .avi?
    Any advice would be much appreciated.
    Jerry Kemp
    Christian Video Ministries
    Ann Bens replied 13 years, 4 months ago 2 Members · 1 Reply
  • Ann Bens
    April 22, 2013 at 10:07 am
    There is no easier format then avi to edit with.
    Solution is to capture in smaller chunks.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
